Joni's Project 96-spec JDM Integra
    We consired to update the ABS to 1999-2000 EK9 abs-unit but those cost a lot and we aren't sure does it fit with K-swap. We need to left something to update so our long winters will not be boring.
      Love it
      Team SunWorks
      Tracktoy: Honda Integra Type R '99
      Summer toy: Honda S2000 AP1 '01
      Daily: Audi A6 2.0 TDi Quattro S-line '18
        More stuff has arrived from Japan!
        Key!s Racing 350mm flat leather steering wheel.
        I'll try to remember to take more pictures about the car today.
          More pics!
          Wavetrack LSD!
          Engine assembly.
          Now mockup'd with Bosch EV14 880cc injectors and custom anodized Aeromotive A1000-fuel pressure regulator and Golden Eagle-fuel rail.
            Engine porn right there.
              ohhh wow!
              quality build!
                Installed the new seats.
                  Something has been done.
                  I laquered Spoon plug cover and painted ITB-horns.
                  Also there is hided some "rare" findings, nr. 27 and nr. 77 Hyper Revs. Nr. 62 is on the way to Finland.
                    Moar pics.
                    Valve cover is now ready. Oil cap threads are raised about 2cm to fit large ARC oil cap and an-fitting is welded to replace oem breather.
                    Roll cage is also now done. Here you see J's Racing C-pillar bar and Cusco rear strut bar.
                      Love the build and great choice of colour
                      1988 CRX
                      1999 Integra Type R
                      2020 Civic Type R
                        Thanks for you all!! . Joba manage the project thread grip on my behalf . we will keep up to date with what is happening in the car my English is pretty bad
                          Even the seat rails are colour coded
                            Yeah,
                            It looks like this.
                            At Friday we try to assemble the passenger door and something else. :gun:
                              Yup..
                              Nothing major hasn't happened. Passenger side door is now assembled and waiting for door cards, but we test fitted the steering wheel and owner tried it.
                              In picture you can see Mugen pedals and Mugen handbrake knob.
                              Also we ordered new final drive from Spoon, 5.1 ratio. Offcourse new ring gear bolts and shims to it. New JDM DC5 5th gear set ordered too to make little bit closer gearing on 4-5 gear and still keep one highway gear.
                              New engine doesn't make power before 6000rpm so need get tighter final drive to get more torque to wheels to make it accelerate better. Also it revs higher so top speed doesn't change that much. That 5th gear change is needed because it doesn't make 500hp, so need some help to accelerate better to 220-230km/h which is about max speed it can get on Finland's racetracks.
                              Left side is original EUDM gearing with new 10500rpm revlimit and right side is modified EUDM gearbox with 5.1 final drive, JDM DC5 5th gear and 10500rpm revlimit.
                                Some update..
                                We rebuilt gearbox shifter "tower" assembly with new parts, old shaft was bent and ruined the plate which holds it in place. Also changed the shift springs to firmer MTEC springs.
                                New JDM-stuff came too from Spoon. 5.1 final gear kit.
                                Merry Christmas for everyone!
