Useful Honda OEM Part Numbers
    A thread to share OEM Part Numbers that might be useful to other members.
    DC2R
    Type R Decals (Side) for CW DC2R
    75783-ST7-Z01ZA
    75773-ST7-Z01ZA
    Type R Decal (Rear) for CW DC2R
    75717-ST7-Z01ZA
      A great list of DC5 part numbers here
      http://www.itr-dc5.com/forum/index.p...-part-numbers/
        FD2R
        RRC intake manifold
        17100-RRC-000
        RRC intake manifold cover
        17121-RRC-000
          Anyone have the part number for the DC5 Passenger door actuator?
          (Not sure if same as USDM / LH or RH)
            Try this site http://jp-carparts.com/honda/figlist...cartype=25408#
              from a B20VTEC with B16A/B18C head build:
              IACV gasket 36455-PT3-A01
              head/block oil control orifice o-ring 15142-PH3-003
              rocker shaft oil control orifice o-ring 91306-PJ4-000
              oil control orifice o-ring 91302-GE0-000
              distributor o-ring 30110-PA1-732
              throttle body gasket 16176-P73-004
              VTEC cam seals 91213-PR3-004
              VTEC rocker cover seal 12341-PR3-000
              bolt washer - rocker shafts 12209-PR3-000
              VTEC Water pump 19200-P72-013
              release bearing 22810-P21-003
              pilot bearing 91006-634-008
              vss o-ring 91304-PT0-000
              14mm drain plug washer 94109-14000
              20mm drain plug washer 94109-20000
              oil strainer gasket 15221-PW0-S01
              MAP sensor o-ring 16075-P07-000
              ECT sensor o-ring 91307-PK2-005
              girdle dowel pins - sml 94301-12200
              girdle dowel pins - lrg 90715-PC6-000
              water to oil cooler o-ring 91316-PE7-730
              oil pump o-ring 91308-PK1-003
              rearmainseal GB end 91214-PLE-003
              oil spout - B20A 11107-PK2-003
              oil pump end seal 91212-PR3-003
              GSR coolant hoses 79721-ST7-000
              B20 coolant hose 79725-SR3-J30
              oil pump washer 15234-PC6-000
              oil cooler water hose 1 19422-PR3-000
              oil cooler water hose 2 19423-PR3-000
              fuel filter 16010-ST5-933
                I recently bought new dc2 type r badges from jdmyard and thought I'd share the part numbers:
                Front: 75700-ST7-E00
                Rear: 75701-ST7-Z00
                Integra Type R 01 #136
                  F22C valve retainer, part number: 14765-PRB-A01
                  F22C retainer keeper ("cotters"), part number: 14781-PCX-004
                  AP2 Oil Banjo/jet bolt: 15290-PCX-000
                    Crush washer part numbers for S2000.
                    Transmission:
                    Fill: 94109-2000 (20mm)
                    Drain: 94109-14000 (14mm)
                    Engine oil drain: 94109-14000 (14mm) same as transmission drain plug
                    Differential:
                    Fill: 90402-pcz-003
                    Drain: 90401-pcz-003
                      I hope other DC2 owners can find the below useful
                      OEM JDM DC2 Type Rx red stitch shift boot - 83414-ST7-Z10ZA
                      OEM JDM DC2 Type Rx Stanley flat clear side indicators - 33802-S3N-J01
                      OEM AUDM DC2 Type R front lip (Championship White) - H0-71110ST7R01ZA
                      OEM DC2 tail light gasket - 33503-ST7-A01
